TwinTurbo.NET: Nissan 300ZX forum - The way to tell is through your oil pressure >
Subject The way to tell is through your oil pressure >
Posted by kZtt on February 16, 2001 at 9:19 AM
  This message has been viewed 31 times.
In Reply To not sure...was thinking any cooler oil would be beneficial > posted by qqqqqqqman on February 16, 2001 at 01:18 AM
Message the design of the TT oil cooler is such that the cooler is only used when oil pressure exceeds 45-50PSI. The cooled oil goes back to the oil pan instead of directly to the engine, so it is not effective for short spikes in oil pressure (eg. under hard accel during drag racing). If you stay below that most of the time, then a larger oil cooler is useless. The NISMO cooler makes sense for Europe when they are running 100+mph for long periods of time on the autobahn.
If you are set on a larger oil cooler, fluidyne makes one for the new corvette that is designed to be mounted in front of the radiator, and maximizes air flow through the cooler. They are a little more expensive than the Stillen or Nismo units though.
